help!
Hi, I have a MacBook Pro, 64 bit, and I have tried to download crew 3.0 but my Mac will not open the setup.exe file as it says Microsoft windows files are not supported by Mac OS. Can someone please help me I have no idea what to do, and don't know much about downloading things...
Creo is NOT a native MAC application and you cannot run it under Mac OS.
You will need to install a Windows emulator on your MAC and run that, then install Creo to your WIndows VM.
If you really want a native MAC CAD check out Siemens NX product, it has been native Mac OS for many years and is what Apple uses.
To install Windows on a Mac see Boot Camp - Apple Support
Emulator is needed only if you need to run Windows and OS X at the same time.
