18-Opal
Apr 21, 2015 7:54 PM UTC
Help identifying old hidden options
I'm in the process of going through all of our config options for our migration from W5 to C3. I found some old hidden options, that I'm clueless on. The person who added them didn't remember much about them either; whether it would be applicable, helpful or hurtful in Creo3. Can anyone help explain some of these options and your opinion on these being set in Creo3 (with Windchill 10)?
  • auto_assembly_with_layouts yes
  • default_object_invalid_refs copy
  • dm_background_operations no
  • dm_emulate_ilink_sys_parameters yes
  • dm_network_request_size 8000000
  • dm_network_threads 8
  • drawing_file_editor editor
  • fix_boundaries_on_import yes
  • graphics opengl
  • intf3d_in_close_open_boundaries yes
  • intf_in_use_template_models yes
  • logical_objects yes
  • nt_cache_dirs yes
  • query_bin_start yes
  • regen_layout_w_assem yes
  • relat_marks_obj_modified no
  • retain_pattern_definition yes
  • spin_control drag
  • standard_hole_note_correction on
Thanks!
Apr 21, 2015 10:24 PM UTC
These are the hidden options I use in Creo 2.0
dm_emulate_ilink_sys_parameters YES
dm_network_request_size 1000000
dm_network_retries 10
dm_network_threads 4
browser_limit_to_ie9_mode yes
obsolete_pre_wf3_layout_replace yes
regen_read_only_insts no
iges_in_106_f2_as_spline YES
David Haigh
jwagh18-OpalAuthor
18-Opal
Apr 21, 2015 10:25 PM UTC
Thanks Dave!
Joseph Wagh
ProEngineer Administrator, Engineer
Office: 201.767.3400 x12521
jwagh@crestron.com<">mailto:jwagh@crestron.com>
Crestron Electronics, Inc.
22 Link Drive, Rockleigh, New Jersey 07647
Crestron Website<">http://www.crestron.com> | Twitter<">http://www.twitter.com/crestronhq> | Facebook<">http://www.facebook.com/crestronhq>
Apr 21, 2015 10:26 PM UTC
I also use:
* graphics opengl
But I didn’t think that was a hidden option. I don’t have it marked as such.
David Haigh
Chris3
Apr 22, 2015 11:18 AM UTC
I am not familiar with them all, but will comment on those I do know about.
  • dm_background_operations no 8000000 - Size in bytes of HTTP upload to PDM. Default is 100000.
  • dm_network_threads 8 - I think there was a thread on this a while back. I don't think this is a valid option anymore. I want to say it was changed in Creo 2 but it might have been 3. You used to be able to change opengl to win32_gdi which bypassed the graphics card and used the CPU for graphics rendering to troubleshoot graphics cards as a source of bugs or Pro/Exits
  • nt_cache_dirs yes
  • spin_control drag
jwagh18-OpalAuthor
18-Opal
Apr 22, 2015 1:03 PM UTC
Chris,
Those were really helpful. Thank you.
Joseph Wagh
Apr 22, 2015 2:23 PM UTC
In Reply to Joseph Wagh:
  • auto_assembly_with_layouts yes - Copies missing objects so the part/feature does not fail
  • drawing_file_editor editor Tries to heal gaps when importing STEP files (maybe IGES too)
  • graphics opengl
Apr 22, 2015 3:20 PM UTC
What is the purpose of: browser_limit_to_ie9_mode yes? Does the option address the Windchill 10.0/Creo 2.0 /IE 10 or 11 compatibility issues?
Mark S. Bohannon
MDA Administrator/Programmer
8001 Development Drive
Morrisville, NC 27650
USA
mbohannon@lenovo.com<">mailto:e-mail>
11-Garnet
Apr 22, 2015 3:33 PM UTC
Mark,
Yes it does. We ran into a huge issue with that last year. Creo 2.0 / Windchill 10.1 is not compatible with IE 10 or 11.
Be aware uninstalling IE 11 will automatically revert to IE 10, but IE 10 has an option turned on that will automatically update IE to version 11. Lovely. We discovered that when we uninstalled IE 11, thinking our computers would revert back down to IE 9 (which had been installed), but IE 11 kept coming back. Then we figured out what was happening.
The embedded browser compatibility options (with both IE and Firefox) are a huge pain.
David R. Martin II
Senior Mechanical Design Engineer
Amazon Prime Air
Apr 22, 2015 3:54 PM UTC
This worked well for us in the couple months between when IT rolled out IE 11 and when we upgraded from 10.1 to 10.2 last week. We first tries the Mozilla based embedded browser but that had poor performance and the Mozilla cache got corrupted a lot so this while unsuppported was a much better option for us.
Does anyone know if there's any negative effects to having this set with IE 11 and 10.2? I suspect a number of users here have it in their local configs so wondering if I need to worry about that...
Abby Dawkins
MCAD Support
KLA-Tencor Corp
Apr 22, 2015 4:04 PM UTC
We've been using it with 10.2 no problems.
David Haigh
