Oct 9, 2012 10:23 AM UTC
Help Mapkeys
Hello friends, I wonder how I can reactivate my mapkeys that I already have because they are already in most settings when I perform the command does not do what it should.
will be that I will have to redo it again and the comondos save mapkeys again ....
grateful for the help .......
Oct 9, 2012 11:45 AM UTC
Hello Andre,
Mapkeys are created by recording picking step by step from "menu". I assume you want reactivate yours mapkeys b/c you reload Pro-E or up garde to newer version of Pro-E. If you still using WildFire then yes you still can reuse the mapkeys that you already have (store in config.pro). But if you are switching from Wildfire to Creo, b/c the "lay out" between WildFire and Creo are different. WildFire is using "menu" and Creo is using "tab". Depend on what you have, some of your mapkeys still work, but I believe most of them don't. Look like you have to create you mapkey from scratch.
DV
Oct 9, 2012 11:56 AM UTC
ok, it was just that we are migrating from WF4 for Creo 2.0 and has some mapkeys that I have yet to use the other not so much now thanks for the help, now is redo all .........
grateful ..........
