help me to open creo software
hi..
guys please help me to open the software.
while double clicking on creo icon it is not getting opened.
as per the tutorial of using trail file,which i got from you tube, i changed the directory of trail file through these method
file-->option-->configuration editor-->found trail file-->chosen one directory other than default one-->add/change-->while saving i had given config.pro then saved the editing.
after this i cant open the creo software.i tried to uninstall the same  for reinstalling.which is also not not working.
i am using windows 10.
i completely stuck with the problem.can u suggest a solution.????
