Sep 25, 2013 2:13 PM UTC
help with best way to check out file
To all,
We are using ProI 3.4 with WF4, probably until some time mid 2014. Our models at times, are large and can have family tables with hundreds of instances. So I am looking for what the best selections during checkout would be, to help reduce the number offiles I really need to check out, and still be able to open my assembly.
Here are two example of the selections I normally make and the number of files associated with each:
Example 1:
- locate top level in commonspace, select the file and do a CHECKOUT
- in the checkout window, choose ALL (dependency), Include Generics, AsStored (Members), update if needed and pick my workspace
- 395 files listed for checkout
- when I go to Pro/E to open the assembly, it gets hung and does not open it
Eample 2:
- in the checkout window, choose ALL (dependency), Include Generics & Include Instances, AsStored (Members), update if needed and pick my workspace
- 6418 files listed for checkout (takes more time as it is 16+ ties the number of files, our server is not local either)
- when I go to Pro/E to open the assembly, it opens
So it seems necessary to include Instances upon checkout, is this correct? Or is there something else that can be selected or changed to only get the fewer files checked out and still be able to open the model.
Any help on this would be appreciated.
Dennis
StephenW
Sep 25, 2013 2:33 PM UTC
There is something wrong. I can't test this now since we don't use Intralink anymore though.
I had always used Dependency (REQUIRED, not all), Include generics (not instances), LATEST (as opposed to as stored).
You only got the files absolutely necessary but not all the instances or all the external references that would be needed for full regeneration.
I never had problems with being able to open the files with that setup.
The only thing I can think of with yours is the as stored condition may not include the latest generic that might be required (although that doesn't really make sense).
Steve
Sep 25, 2013 3:23 PM UTC
Stephen,
I am trying this now to see if it helps me. The only thing I did different, is I selected AsStored. We are supposed to work with the latest relesed files in our models, and this is what is supposed to have been stored.
Dennis
