hi
Myself mukesh ,from india i want to know how to change proe default color in drawing mode and how to save in config.pro file?
please help me.
Mukesh
StephenW
To get to the system colors,  go to file options system colors.
Once you set the colors the way you like them, save the system colors file
Add the option SYSTEM_COLORS_FILE to your config.pro and use the browse function to locate the file you saved.
18-Opal
June 2, 2017
Hi Mukesh,
Please let us know if you could follow the instructions provided by Stephen?  If not, please let us know which release of Creo Parametric you are using?  I can try to attach some screen shots.
Amit
