Hide invisible lines on Drawing
Hi guys,
I can't figure out how to adjust the settings for the following case. There's line (that lower part of the hole) that should be invisible because it is behind the object (bracket).
Any ideas? Everything else is great.  Thank you 🙂
StephenW
In the view properties, do you have the view display set to NO HIDDEN?
If there is intereference in parts assembled, that can also sometimes cause odd display issues.
pvn1-VisitorAuthor
Yes. It is set to NO HIDDEN. And there are no interferances. Are there any other settings that might affect this?
2-Explorer
December 8, 2017
The other possibility is that it's a surface which is controlled with a separate setting, particularly in section views.
StephenW
Can you share the drawing and models with us? It would be much easier to figure out.
Isthere any sketch or curve that is not hidden?
