hole charts on multi sheet drawings
  • August 12, 2011
  • 727 views
Everyone
We have a multi sheet drawing where every sheet has a different model, and
likely a different size format. There are drawing hole charts on some of
these sheets to locate the hole position. If the active model is changed
the text size within the charts of different models changes.
Say the active model of the drawing is changed to one that uses a hole
chartt on a dsize format- then the text in hole charts on the bsize sheets
gets bigger than the table.
I don't know if it is a glitch or if there is some dtl or other config
that needs set. I will try to post screen shots.
any help would be appreciated.
Eric Henriksen
Entegee Engineering
Davenport Iowa
Off topic, but related reply.
ASME Y14.1 says that all sheets of a drawing should be the same size.
On topic reply.
The problem you are seeing is caused by having different sheet sizes. The dtl file can only specify one set of parameters per file.
Thank you,
Ben H. Loosli
USEC, INC.
