3-Newcomer
Jun 13, 2012 7:48 AM UTC
how can I open a creo 1 .prt in wildfire 4 ?
How do I go about opening a creo 1 .prt in wildfire 4 and what config.pro options do I need to set ?
Jun 24, 2012 6:41 PM UTC
Is the GCRI solution favorable to loading many versions of Pro/E to stay compatible with many clients?
Jun 22, 2012 2:24 PM UTC
3D software has never been forwards compatible, meaning that you cannot open a newer version of a file in an older version of the software.
It does, however, work the other way around.
Jun 24, 2012 5:28 PM UTC
Sylvain's nailed it. There are actually some options for this... although it's a bit of jumping through hoops in my opinion. I'm not sure the status of GCRI with Creo but it's your best shot.
