Dec 27, 2015 12:42 PM UTC
How can you delete all files before .prt.X the latest version
How can you delete all files before .prt.X the latest version or even before the latest version as well as other unnecessary files on all hard disk.
Obviously, a backup of the hard disk was made before.
In time there was a program that spanked this very well: "Spekpur"
Is there now a single program that can do this in one go.
Best regards.
Denis.
    KenFarley
    KenFarleyAnswer
    Dec 28, 2015 1:59 PM UTC
    I don't know of any program that can be run from within Creo to do this, but I have a DOS batch file that does. It uses the program that is supplied with Creo, called "purge.exe". For me, it's located in "C:\Program Files\PTC\Creo 2.0\Common Files\M160\x86e_win64\obj".
    The batch file I made traverses the directory structure and "purges" each directory, which deletes all earlier versions of the file types associated with Creo, like *.asm.*, *.prt.*, etc. I've also, as you'll see, added other deletions, like getting rid of .m_p files and other temporary files Creo seems to like to create. Since .bat files can't be downloaded by a lot of users, here is the text of the file:
    --- [ Begin recpurge.bat ] ---
    :: Date   * 30 August 2015
    :: Author * Kenneth J. Farley
    :: Recursively traverses the directory structure, starting at the current
    :: directory, and executes a purge and any other commands necessary. The
    :: pseudocode for this is as follows
    :: (1) Generate a list of directories
    :: (2) For each of the directories
    ::     a. change to that directory, via a "pushd"
    ::     b. Execute the desired commands
    ::     c. change back to the original directory, via "popd"
    @echo off
    for /r /d %%d in ("*") do call :doPurge "%%d"
    exit /b
    :: This code is executed for each directory visited. The primary purpose is to
    :: run the "purge" command, but it's also helpful to get rid of any other stray
    :: files that Pro/E creates in the normal course of operation.
    :: Note: The "2> nul" construct is used to throw away any "file not found" type
    ::       errors generated when the delete command doesn't find the target files
    ::       provided to it.
    :doPurge
    pushd %1
    echo Processing %1
    c:\ptc\purge
    :: Windows generated files
    del /ah Thumbs.db 2> nul
    :: PTC General files
    del APS00W07 2> nul
    del current_session.pro 2> nul
    del datafile.ers 2> nul
    del errors.lst.* 2> nul
    del fix_params.log 2> nul
    del *.acc 2> nul
    del *.crc 2> nul
    del *.err.* 2> nul
    del *.idx 2> nul
    del *.inf.* 2> nul
    del *.log.* 2> nul
    del std.err 2> nul
    del std.out 2> nul
    del trail.txt.* 2> nul
    del *.xpr 2> nul
    del *.tst 2> nul
    :: PTC Manufacturing files
    del *.acl 2> nul
    del *.lst 2> nul
    del *.mbx 2> nul
    del *.ncl.* 2> nul
    del *.ncl_a.tab 2> nul
    del *.ncl_b.tab 2> nul
    del *.ncl_c.tab 2> nul
    del *.ncl_x.tab 2> nul
    del *.ncl_y.tab 2> nul
    del *.ncl_z.tab 2> nul
    del *.tap 2> nul
    popd
    exit /b
    --- [ End recpurge.bat ] ---
    Modify the program to look in the proper directory for the "purge.exe", add or delete other files to "clean up", etc.
    As usual, I'm not responsible for any troubles you encounter in using this technique. As with any such utility, you will want to test it out on a small directory first before unleashing it on a large directory structure.
    Also, I always run this in a "Command Prompt" window, don't know if it works well any other way.
    KenFarley
    KenFarley21-Topaz IIAnswer
    @echo off
    exit /b
    ::       provided to it.
    :doPurge
    pushd %1
    echo Processing %1
    c:\ptc\purge
    del APS00W07 2> nul
    del *.acc 2> nul
    del *.crc 2> nul
    del *.err.* 2> nul
    del *.idx 2> nul
    del *.inf.* 2> nul
    del *.log.* 2> nul
    del std.err 2> nul
    del std.out 2> nul
    del *.xpr 2> nul
    del *.tst 2> nul
    del *.acl 2> nul
    del *.lst 2> nul
    del *.mbx 2> nul
    del *.ncl.* 2> nul
    del *.tap 2> nul
    popd
    exit /b
    Dec 28, 2015 4:49 PM UTC
    Hello Kenneth,
    Thanks for your reply.
    You have a good knowledge of the back.
    Me, this is very long I did do BATCH file.
    All these functions are under the back of W7 pro 32-bit sp1.
    Kind regards.
    Denis
    Dec 28, 2015 4:08 PM UTC
    Technically, Purge.exe should do this for you in the command prompt window for a complete folder.
    Problem is, a lot of installations didn't recognize purge as a DOS command due to some mis-located or wrongly path'd DLL files.
    Kenneth... THANKS!
    KenFarley
    Dec 30, 2015 11:56 AM UTC
    Yeah, we have had this "habit", since the dawn of time (Pro/E V8.0?, around 1994) of copying the "purge.exe" executable into every directory we work on. Then you can double click it in an explorer window and it handles that one directory.
    I wrote the recpurge thing a while ago, back when our file server had a relatively small hard drive. Some directories that might have "really" needed 10-20 Mb of space were using 500-ish because of massive numbers of old version files. With this thing I was able to keep the old hard drive hobbling along for quite a while. Plus, it really speeds up things when you need to do a search.
    Jan 4, 2016 1:25 PM UTC
    ProESite - Olaf Corten's Pro/ENGINEER Site - Pro/E Utilities, Benchmark, Tips and Links
    Check out CreoPurge found in the Utilities section of the above web site. We've installed it on all users computers. It works with a simple right click.
    Jan 4, 2016 1:58 PM UTC
    Hello Kevin,
    Thanks for reminding me this site, that I had forgotten.
    I'll enjoy to see what's new.
    Kind regards.
    Denis
    2-Explorer
    Jan 20, 2016 5:13 PM UTC
    Hello Denis,
    if either (or both) suggestions (batch script using purge.exe or CreoPurge) helped you solving your issue, please get back to the thread, share your experience and mark the thread as answered (by selecting the most appropriate post as Correct Answer).
    Gunter
