9-Granite
How create parameters with accentuation using Model Check?
I am using Creo Parametric Release 10.0 and Datecode10.0.8.0
Here are the errors that I faced
I'd like to create parameters via model check, but it's absolutely essential that the parameters have accents.
Here's an example:
ASM_PARAMETER DENOMINAÇÃO STR EQ PDM
PRT_PARAMETER DENOMINAÇÃO STR EQ PDM
DRW_PARAMETER DENOMINAÇÃO STR EQ PDM
    Mahesh_Sharma
    22-Sapphire I
    Hi @Victor_Brumatto
    I think setting MC_SUPPORT_LEGACY_STRING to Y in config_init.mc should help you.
    Reference article https://www.ptc.com/en/support/article/CS210551
    Thanks.
    Mahesh_Sharma
    22-Sapphire I
    Hi @Victor_Brumatto
    Thanks.
    9-Granite
    Tks for help me.
