May 29, 2015 12:16 PM UTC
How do i combine an annotation with an attribute?
Hi, i want to combine an annotation/pos (item number) in the graphic view with one of our attributes (other than the standard item name) - is that possible?
ex.
1 - OLHE
("1" is the normal item number and "OLHE" is the attribute "Author" from Parametric)
nordligAnswer
May 29, 2015 2:03 PM UTC
I managed to find the answer at support.ptc.com.
Change the CalloutTemplates.XML in AppData under you user profile and the in the illustrate installation folder - there are two and they are buried deep down in the file structure. Make a search!
The solution below shows up but it has no label in the ribbon, and it works - just change the WHATEVER int o your specs.
<annotation id="WHATEVER" hasLeaders="true">
      <name locid="WHATEVER"/>
      <description locid="WHATEVER"/>
      <tooltip locid="DEFItemNumberTooltip"/>
      <thumbnail url="itm_prop2.png"/>
      <leaders>
        <line-style weight="1pt" color="#000000" halo="false" dashes="Solid" start="none" end="none"/>
      </leaders>
      <label canEdit="false">
        <text font="Arial" size="10pt" color="#000000">
          <useproperty category="System" name="pvITM"/> - <useproperty category="WHATEVER" name="WHATEVER"/>
        </text>
        <shape type="roundrect" border="true"/>
      </label>
    </annotation>
nordlig10-MarbleAuthorAnswer
      <leaders>
      </leaders>
        </text>
      </label>
    </annotation>
