Apr 15, 2016 12:28 PM UTC
How do you import a table in the Function Definition dialog box within Mechanica or the Simulate module?
In my simulation, I'm trying to import a table in the Function Definition dialog box. What file types/formats are supported? I've tried CSV, XLS, XLSX, TXT but none of them work. The only error message I receive is "Error reading the file."
ehaenenAnswer
Apr 15, 2016 7:50 PM UTC
Hi Drew
A .txt file, made in notepad should do the trick
use a space or a tab between the x and y values as in the attached example
Good luck
Erik
ehaenen1-VisitorAnswer
Hi Drew
Good luck
Erik
Apr 18, 2016 11:54 AM UTC
Thank you so much!
