Mar 16, 2010 6:15 PM UTC
How to add purge.bat to the right-click in Windows 7
Since no one posted a solution I trudged thru it, here it is, should work in XP as well.
Copy the following text to a text file.
Then rename the file to "right-click_purge.reg" (Remove "s)
Begin Copy BELOW This Line ------
Windows Registry Editor Version 5.00
[HKEY_CLASSES_ROOT\Folder\shell\purgeproe]
@="Purge Pro/E Files"
[HKEY_CLASSES_ROOT\Folder\shell\purgeproe\Command]
@="cmd.exe /c cd %1 & \"c:\\ptc\\proeWildfire 5.0\\bin\\purge.bat\"
Stop Copy ABOVE This Line -------
You may have to change the path in the last line to suit your Pro/E install.
Once you have the file created, double click it to add info to your registry.
I TAKE NO RESPONSIBILITY FOR YOU KILLING YOUR COMPUTER IF YOU DON'T KNOW WHAT YOU ARE DOING! Backup your registry before doing this.
Mar 17, 2010 5:59 AM UTC
Hi Mike,
Sorry never saw the post before but here is how we do it for XP
See attached rar file which has the attached pdf and .bat file.
Rory
