Mar 20, 2016 2:23 AM UTC
how to change default font display in Drawing Creo 2.0. i used in config default_font CG Omega
how to change default font display in Drawing. i used in config default_font CG Omega. drawing always fonts are Shows Font.ndx style. some times its automatically changed to Font.ndx in same drawing .1.JPG2.JPG3.JPG
Mar 20, 2016 10:44 PM UTC
I suspect you need the NDX file name of the font.  It will not have spaces.
edit: or a TTF.  Enter cgomg.ttf and the font will take.
2-Explorer
Mar 20, 2016 10:27 PM UTC
Depends on where the drawing is from. If you are using a template drawing, the font is set in that template and copied to the new drawing. The config only makes a difference if the drawing is created without reference to any other existing drawing. You can import a drawing config to replace the current config to make changes like this.
