Oct 9, 2015 4:31 PM UTC
How to do a section in an axonometry wiew in drawing?
Hi
I have to do an axonometry wiew but with a section! And if is possible in shading with edge rappresentation as in the picture below!
I did this saving the jpeg file and putting it as object in drawing, is the only way to do it?
Thanks!
Oct 12, 2015 6:09 AM UTC
Luca,
you can use following procedure:
1.] add x-hatching default real number parameters into your model (Tools > Parameters)
default_xhatch_angle
default_xhatch_spacing
See details in http://help.ptc.com/creo_hc/creo30_pma_hc/usascii/index.html#page/pma/fundamentals/fund_four_sub/To_Set_the_Default_Spac…
These parameters drive x-hatching properties displayed on the drawing.
2.] create Zone (3D x-section) in your mode ... see myzone in my model (created in CR2 M070)
3.] in drawing view properties in Sections category set 3D cross-section myzone
You cannot modify x-hatching of 3D x-section in Drawing mode!!!
MH
Luca,
MH
lnessi1-VisitorAuthor
Oct 12, 2015 11:38 AM UTC
It works thanks!!
I have a little question more!
I have to do it in an assembly, is possible to exclude any components? an example screws, nuts exc...
Thanks!
Oct 12, 2015 12:13 PM UTC
Luca,
I tested below described procedure using assembly with 2 components.
In Assembly mode:
1.] I defined zone
2.] I defined layer and put unwanted component into it
3.] I hid the layer and saved layer status into layer state (Layer_State002_1Comp)
4.] I defined combined state (Comb0001 referencing Layer_State002_1Comp)
In Drawing mode:
5.] I created view referencing combined state (Comb0001)
If you do not understand my procedure, please let me know. Tomorrow I can prepare example data for you.
MH
