Oct 8, 2014 12:56 PM UTC
How to exit Creo 2.0 without saving changed objects
I would need a help with config.pro setting so that i am not prompted to save changed (unsaved) objects.
in my config.pro file the option "prompt_on_exit" is set-up to NO...
Thanx in advance.
Oct 8, 2014 5:57 PM UTC
Default is no, so yes to this option much generate a different dialog than the "beware, you are about to mess up" prompt if you have changed objects in session.
Oct 8, 2014 5:58 PM UTC
Welcome to the forum, Tomas!
