20-Turquoise
November 21, 2014
How to get a weblink "pfcBaseSession" object?
Creo Parametric 2.0 M130
I want to use weblink to get the current value of a config option.In my case I want to get the value
of start_model_dir.
According to CS122393 it should be as simple as using pfcBaseSession.GetConfigOption(). However when
I attempt to do this:
var startModelDir = pfcBaseSession.GetConfigOption("start_model_dir");
I get a javascript error:
pfcBaseSession is not defined
So obviously there is more to this than what CS122393 states.
Does anybody have a working code snippet that uses any of the pfcBaseSession weblink methods they
would be willing to share?
Good morning,
if you want to learn how to start with Weblink it is neccessary to read the "Introduction" chapter in the Weblink API documentation.
There are examples how to get the session object and the important pfcCreate() method.
The Weblink API doc can be found in the folder <creo_installation_dir>/Common Files/M130/weblink/weblinkdoc.
Andreas
MikePhillips
Randy,
Try this
var session = pfcCreate("MpfcCOMGlobal").GetProESession();
var dir = session.GetConfigOption("start_model_dir");
Mike Phillips
Raytheon
-----Randy Jones <-> wrote: -----
20-Turquoise
November 24, 2014
On 11/24/14 09:55, Michael D1 Phillips wrote:
> Randy,
> Try this
Perfect!
That is exactly what I needed but couldn't arrive at from the weblink users guide or the javascript
examples.
I had tried all combinations of
var baseSession = pfcCreate("MpfcBaseSession");
var baseSession = pfcCreate("pfcBaseSession");
and then
baseSession.GetConfigOption("start_model_dir");
Thanks.
> Regards,
> Mike Phillips
> Raytheon
> To: -
> From: Randy Jones <->
> Date: 11/21/2014 03:09PM
> Subject: [proecus] - How to get a weblink "pfcBaseSession" object?
> of start_model_dir.
> Thanks
Hi Randy,
If it's still relevant on the following link found following solution:
  • The variable is a handle of the active Creo session. It could be retrieved (Interface) and could not be instantiated
  • we can simple get via casting pfcBaseSession <=> pfcSession
  • Example:
session=(new ActiveXObject ("pfc.MpfcCOMGlobal")).GetProESession ();
//the GetProESession returns a pfcSesson object
session.GetConfigOption("regen_failure_handling");
//pfcBaseSession method from a pfcSession object is automatic get along the
// inheritance of the object
Aduard
