How to get past "please exit the already running installer..." error?
I'm trying to install the latest version of Creo.  Something happened where things hung on my initial install and now when I try to run the setup app, it gives me the exact same error as is discussed in https://www.ptc.com/en/support/article/CS323172
This article directs me to kill setup.exe, but I don't see that anywhere in my task manager.
I've tried restarting my computer, and the issue persists.
Does anyone have any ideas on what I could do to get past this?  Is there some sort of bread crumb or other setting that I need to clear?
Thank you.
The installer creates a log file that may be preventing you from restarting the installer. It is in your home directory, I think.
Also, did you delete all remnants of the initial Creo install before trying it again.
