Oct 18, 2016 6:49 PM UTC
How to reconfigure the installation of Creo Parametric 3.0
  • How to reconfigure the software ?
  • How to configure the software to point to the license server ?
  • Error message is recieved:
License requested failed for feature XXX: Invalid feature name:[FEATURE_NAME]
  • Reconfigure the software with License AAX
  • Unable to run the software and get the following error:
  • Unable to activate Reverse Engineering extension
Apr 4, 2018 12:27 PM UTC
This seems like an old post.  In case it's still useful, here is what I do through my configurator:
  1. Declare a couple of environment variables in your launching script, such as:
    1. set LICENSESERVER=7788@10.257.257.258               (Put your appropriate server here).
      set LICENSEOPTION=PROE_MechModel (93 209)            (These are for Reverse Engineering)
  2. Open the file parametric.psf (usually located at the \Parametric\bin\ folder) and modify the following lines:
    1. ENV=PTC_D_LICENSE_FILE=%LICENSESERVER%
      ENV=CREOPMA_FEATURE_NAME=%LICENSEOPTION%
That should allow you to solve your issue without reconfiguring Creo every time, but you still need to update the environment variables by hand when your need changes.  I hope this still helps someone.
