Apr 22, 2013 6:42 AM UTC
how to remove chechout and revise command
I need assistance about the command customisation on creo Parametric. Is there any way for removing the checkout and revise command from the Creo Parametric file menu ? This command causes some missing action such us cad part and wtpart isnot synchronised together, so i need to force users to the cabiend to do a revise action.
Thanks for any comment
Serkan ACAROGLU
Apr 22, 2013 11:12 AM UTC
Hello Serkan.
To my knowledge there is no way to remove the "Revise and Check Out" action from the File menu.
We are now on 10.1 and I actually logged a case against this behavior back in WC9. Nothing has been done to sync the functionality between Creo workgroup mgr and Windchill actions.
We instruct our Users to not use this menu pick in the Creo->Fle menu.
KR, Jim
sacaroglu1-VisitorAuthor
Apr 25, 2013 2:53 PM UTC
Hello Jim,
Thanks for your explanation, i am looking for any customisation method to remove this command from any place ( menu, rmb etc. ) in the Creo ui. For the time being, i am using the customise screen option and removing this command from File menu.
serkan
