How to replace the model of a drawing
The same method I used previously can be used to more complex jobs. Here is a mapkey I made to replace the model of a drawing with just a few clicks. Just tested in Creo 2.
Open just the drawing in memory and call mapkey "rm", then select a new model and press "resume". That's it
Jose
Edit: just attached a Creo 3 version.
Hello Jose,
Please explain, what i need to do with the file replace_model_CREO_3.pro?
Where i should put it? And what are the next steps?
Thank you in advance
Sari
Open the file with a text editor, copy/paste  the text into your config.pro.
Restart Creo and follow the instructions:
Open a drawing, call mapkey "rm", then select a new model and press "resume".
It's a little bit long mapkey that does all the manual work for you, these are the steps (from what I remember now):
1 - Capture drawing name
2 - Capture original model name
3 - Asks to select a new model and captures its name
4 - Close everything and clears from memory
5 - Open new model and rename it to the old model ("just in session")
6 - Opens drawing
7 - Re-open model and renames it to original name("just in session")
8 - Open and save drawing
9 - Close everything and clears from memory
10 - Open drawing
It has been working for me, please give some feedback to know if it is working to you too
Jose
Thank you, Jose
I will test it.
Sari
Hi everyone!
Have any of you tried this mapkey with CREO 3.0 M120? I am not sure if I am following the mapkey steps correctly because it does not work.
Thanks!
