3-Newcomer
How to set Italian language in Creo Paramteric
I am using Creo Parametric Release 6.0 and Datecode6.0.3.0
Creo language in Italian language
The italian language has been installed, I've tried with ENV=PRO_LANG=Italian both in the parametric.psf and Set in the system variabile but none of that id working
Thank you
3-Newcomer
Hi
I did all of what is prescribed but it does not work..
Thnak you anyway
Dale_Rosema
Contact your VAR, they should be able to help you.
I guess you did not select Italian language item during installation. Check whether you installation directory contains italian subdirectories. If they do not exist then you have to uninstall Creo and install it again from the scratch.
3-Newcomer
Hi
I've checked and the Italian language has been installed
I've both checked the installation setup with the reconfigure.exe command and the languafge folder in the instyallatin directories..(I can find many italian subdirectories the inside the main PTC installation folder..)
thank you
@SM_6285725 wrote:
Hi
thank you
does this mean that you can run Italian Creo ?
