How to solve Creo files opening up very slowly.
I am using Creo Parametric Release 8.0 and Datecode8.0.0.0
Creo user is experiencing long delays opening up Creo files. Sometimes longer than 3-4 minutes. Mainly solid models. Sheetmetal models appear to be better.
StephenW
I would remove config.pro/config.sup/customization files and retest to rule out a configuration issue. Extensive search paths can do this.
If using pdmlink, make a new workspace and test.
If No file management, then isolate files in one folder and re-test. (possible issues are network related)
There are likely a bunch of other potential issues, but this is where I would start.
Thanks for the reply but this did not help.
This issue is a bit odd because the user has the same computer set up as other Creo users and it appears to be an isolated issue.
Thanks again.
Are others having issues opening the same files that are slow on that one computer?
