I can't change user interface's Lanauage from English to Chenese traditional
- 8 replies
- 4022 views
- Translate All
Hi Partners,
I want to run Creo Parametric in Chenese traditional. (Creo Parametric version is 9.0.0.0)
I have already try the following method and it doesn't work.
1. Set environment variable LANG or PRO_LANG to cht (for Traditional Chinese ).
2. Run reconfigure.exe to add Chinese_translation, but I can't find this option in it. (show in attach picture)
3. Open "Configuration Editor", and set these option to Yes (dialog_translation / help_translation / menu_translation / msg_translation).
Is there any other method can suggest? or, should i open a support case?
