When i proceed to the install licensing page the place where we have to enter the license isn't usable(can't click it). I am using windows 8. So i downloaded the win8/8.1 version from PTC website. But still it doesnt help.
If you have got a license file (in text format), try drag and drop license in Source column under License summary. If it fail to work, submit a academin TS case at
If you have an existing license server ro license use License summary column, Under Source column in License summary Enter 7788@servername or drag and drop license file (if locked license)
Before starting the installation process check the MAC Address of machine, get a new license file and later start the installation of Creo, when installing Creo you can use earlier information to define server.
If you find difficulty in installation, better ask for help from Technical support. TS engineer will help you with license server and Creo installation.
Also make sure when you run the setup.exe to RMB on the file and chose "Run as Administrator". Sometimes if you don't run it that way it not install correctly and I have seen it not allow me to drag and drop my license.txt file into the License Summary Source empty box. Hope this makes sense.
