Apr 2, 2015 4:42 PM UTC
I need instruction on setting up default configurations
I need instruction on setting up default configurations. I am having to change settings every time I start a new sheet metal part or drawing. We have only two seats for now and no administrator with PTC Creo experience. We have had very limited success getting help from PTC.I need complete instruction in the form of a book or documents that walk me through it as if I'm stupid. Specifically I need to do things like set scale to more decimal places then the dimensions, or just change the default number of decimals, have scale display differently then the dimensions, change the default text size and use windows fonts, change the K-factor and default bend radius etc. The list goes on. Part of the problem is that we use Microstation primarily, and adopted PTC Creo for a specific project because our customer uses Creo and Microstation couldn't handle the large models that will be needed for the job. I see us slowly adopting Creo over time but couldn't get any training etc for the two seats we currently have.
davehaighAnswer
Apr 2, 2015 5:24 PM UTC
Although the ProE Admin presentation was done on Wildfire not Creo, amost all of the information is still valid. This may not address all your questions but it will get you started down the right path.
You'll need an account on the PTCUser site to view a couple of these
ProE Admin 101 presentation:
http://portal.ptcuser.org/p/do/sd/sid=1144&type=0
The following presentations are based on Creo
Creo Admin 101
http://communities.ptc.com/servlet/JiveServlet/download/3205-5-45122/CUST134_Creo_Creo_Admin_101_Haigh.pdf
Creo Admin 102
http://communities.ptc.com/servlet/JiveServlet/download/3883-21-54294/CUST110_Creo_Admin_101_Haigh.pdf
An Admin's guide to License Managment
http://portal.ptcuser.org/p/do/sd/sid=2464&type=0
davehaigh13-AquamarineAnswer
Creo Admin 101
Creo Admin 102
Apr 2, 2015 5:41 PM UTC
Check out this book on Amazon.com:
Creo Parametric 2.0 Tutorial by Roger Toogood and Jack Zecher
