i want print (creo parametre or pro/enginer)
  • May 29, 2013
  • 3 replies
  • 1679 views
hello i'm Jo
I "C++" want to print from. and file format is ".drw".
Without a mouse or other actions "c + +" in the print must.
But I "creo" and "proe" can not find command line print.
print parameter or the other way to me and let me know. plz....
If there is no way, should not tell me.
Methods have been looking for a week.
if you want to print .drw file, you have to install ProE or Creo Parametric on your PC.
Martin Hanak
thank Martin Hanak
but, ProE(WF5) and creo(2.0) is installed.
I use it only when the output command is.
I guess you can define mapkey in ProE/Creo for printing purposes and call this mapkey from Pro/TOOLKIT application. This could be an alternative for command line print.
Martin Hanak
