Import parasolid file
I am using Creo Parametric Release 6.0 and Datecode6.0.6.0
Parasolid files (x_t) when imported in CREO 6.0.6.0 not visible but it is opening and visible in CREO 10.
    What version is your Parasolid file?
    It should be above R30 as it is not opening in creo 6.
    Is there any method to check
    open the file in Notepad. Maybe you will see some version information in file header,
