May 4, 2011 10:17 AM UTC
In Accessory window Pan Zoom with mouse is not working
I am creating an Accessory window with the command ProAccessorywindowCreate and displaying the model in it. I could not zoom or pan the model with mouse. The application hangs if I move the window. Any other window can be used or how to make the window that it allows to zoom.
Thanks in Advance.
Joseph
    May 4, 2011 3:31 PM UTC
    Joseph,
    I would have to see your code to determine if the call to the API was made
    incorrectly (however unlikely, it's a simple API). I have a few questions
    though:
    1. What version of Pro/ENGINEER are you using (Arch, Version, Build)?
    2. What is the reason for using the accessory window vs. a "real" window
    a la ProObjectwindowCreate()?
    3. Did you subsequently call ProMdlDisplay() and ProWindowCurrentSet()?
    4. In the 2 code examples for this API I see that the purpose of the
    accessory window was to have the user select some geometry and then the
    window is deleted. Is this also your use case (may be same answer to #3)?
    PATRICK S WILLIAMS
    Information Technology
    Mechanical Engr Solutions
    Missile Systems
    Raytheon Company
    +1 520.545.6995 (office)
    +1 520.446.0244 (pager)
    +1 520.545.6399 (fax)
    6221 S Palo Verde Rd
    Tucson, AZ 85706-5093 USA
    www.raytheon.com
    Follow Raytheon On
    This message contains information that may be confidential and privileged.
    Unless you are the addressee (or authorized to receive mail for the
    addressee), you should not use, copy or disclose to anyone this message or
    any information contained in this message. If you have received this
    message in error, please so advise the sender by reply e-mail and delete
    this message. Thank you for your cooperation.
    May 5, 2011 5:22 AM UTC
    Patrick,
    Thanks for the reply,
    Here I have my answers to your questions.
    1. I am presently using wildfire 4.0 M160.
    2. Just I want to show the model to the user, it is just for viewing purpose only.
    3. I am using the commands in this sequence. ProAccessorywindowCreate() -> ProwindowActivate() -> ProMdlDisplay() -> ProwindowRefit().
    Joseph
    FV_01
    May 5, 2011 12:09 PM UTC
    Hi all,
    This should work:
    #if PRO_VER > 29
    err = ProAccessorywindowWithTreeCreate( mdl_name, mdl_type, PRO_B_FALSE, &w_id);
    #else
    err = ProAccessorywindowCreate( mdl_name, mdl_type, &w_id);
    #endif
    err = ProWindowCurrentSet( w_id);
    err = ProMdlDisplay( mdl);
    ProWindowRefit( w_id);
    FV.
    May 5, 2011 2:52 PM UTC
    I agree with Feliks' code snippet. The API ProWindowActivate() can only
    be called in an asynchronous graphic mode only application. It does no
    good in a synchronous dll application.
    Function ProWindowActivate
    Description
    Activates the specified window.
    May 10, 2011 5:12 AM UTC
    This is not working for me, because I trigger the Accessory window from User Interface. I have a button called preview, in the user interface, whenI press the preview button, accessory window created.Both User Interface and accessory window present, when I try zoom or rotate the model in the Accessory window.
    when I close the User Interface still the window present, I have not destroyed, now it zooms and pan is working.
    Joseph
    May 10, 2011 2:42 PM UTC
    Ah! That makes a bit more sense. Let me summarize my understanding of
    the situation.
    1. Your program is launched and a User Interface is shown. Is this a
    ProUIDialog (.res file) user interface?
    2. The user works with the User Interface and finally clicks the Preview
    button. This action creates and shows the accessory window.
    3. The user tries to pan/zoom in the accessory window and cannot.
    4. The user closes the User Interface and tries to pan/zoom in the
    accessory window and is successful.
    If my understanding is correct then my suspicion is that the User
    Interface was created as a modal dialog box (.DialogStyle =
    PROUIDIALOGSTYLE_PARENT_MODAL). Try using some of the other .DialogStyle
    values for your dialog box. Read the API Wizard under User's Guide->User
    Interface: Dialogs->UI Components->Dialog Attributes and click on the
    .DialogSyle link to read more about the other possible values. I hope
    this helps.
    typedef enum
    PROUIDIALOGSTYLE_MENU_MODAL = 0,
    PROUIDIALOGSTYLE_MODELESS =1,
    PROUIDIALOGSTYLE_PARENT_MODAL =2,
    PROUIDIALOGSTYLE_APPLICATION_MODAL =3,
    PROUIDIALOGSTYLE_MESSAGE_MODELESS =4,
    PROUIDIALOGSTYLE_MENU_MODELESS =5,
    PROUIDIALOGSTYLE_WORKING =6
    }ProUIDialogStyle;
    PATRICK S WILLIAMS
    Missile Systems
    Raytheon Company
    www.raytheon.com
    Follow Raytheon On
    May 10, 2011 4:59 PM UTC
    Joseph,
    I created a sample application that has a simple parent modal dialog box
    that allows the user to browse for an object. Then the user can click the
    Preview button which creates an accessory window. I was able to pan/zoom
    in the accessory window just fine. I am using WF 4.0 M130 x32. Here is
    the code snippet for creating the accessory window. In short I was not
    able to reproduce your issue.
    void PBPreviewAction(char *dialog, char *component, ProAppData data) {
    ProError pro_error =
    PRO_TK_NO_ERROR;
    wchar_t *wszFullPath = NULL;
    ProName pro_wszName,
    pro_wszExt;
    ProMdl pro_mdl =
    NULL;
    ProMdlType pro_mdlType =
    PRO_MDL_UNUSED;
    int nWindowId =
    0;
    //Get the input panel value
    pro_error = ProUIInputpanelWidestringGet(dialog, "ipPath",
    &wszFullPath);
    //Parse the file name
    pro_error = ProFilenameParse(wszFullPath, NULL, pro_wszName,
    pro_wszExt, NULL);
    //Free the input panel value
    pro_error = ProWstringFree(wszFullPath);
    //Get the model type
    if(!wcscmp(pro_wszExt, L"prt"))
    pro_mdlType = PRO_MDL_PART;
    else if(!wcscmp(pro_wszExt, L"asm"))
    pro_mdlType = PRO_MDL_ASSEMBLY;
    else
    return;
    //Open the model in an accessory window
    pro_error = ProMdlRetrieve(pro_wszName, pro_mdlType, &pro_mdl);
    pro_error = ProAccessorywindowCreate(pro_wszName,
    (ProType)pro_mdlType, &nWindowId);
    pro_error = ProWindowCurrentSet(nWindowId);
    pro_error = ProMdlDisplay(pro_mdl);
    PATRICK S WILLIAMS
    Missile Systems
    Raytheon Company
    www.raytheon.com
    Follow Raytheon On
    May 12, 2011 2:38 PM UTC
    I am using MFC UI. If I make the MFC UI non modal, UI quits immediately, after it is created. I donot understand the prob.
    Joseph
    May 17, 2011 6:30 AM UTC
    Thanks for the reply. Hope that will work for Pro/toolkit UI, I am using MFC in my application and the User Interface is of MFC. I have tried to make the User Interface Modeless, but the UI quites very immediately after the creation.
    Joseph
    May 19, 2011 5:19 AM UTC
    I have resolved the Issue, the Issue was I have created the dialog as local variable, so it is destroyed after the function execution is over. Now I have created the dialog as Pointer variable, so that it lives even after the function execution is finished.
    Joseph
