Install Creo4 and Creo7 on same machine
I am using Creo Parametric 7.0 7.0.0.0
Hello, is it possible to install both Creo7 *and* Creo4 on same machine?
    tbraxton
    Yes, it is possible.
    Dale_Rosema
    Just remember that you have to keep the models/files separate. If you save a Creo4 model with Creo7, it will now be Creo7 and it is not backwards compatible.
