Intelligent Fastner not working
I am using Creo Parametric Release 11.0 and Datecode11.0.0.0
Error message: "Customizing parts is not available in the standard version. Please contact your account manager to upgrade." when trying to add a fastner to an assembly. This was available for us in Creo 10.
1.] compare Creo 10.0 license file with Creo 11.0 license file
2.] IFX license code = 346
3.] IFX license code may be included in Creo license INCREMENT block -OR- it can have separate INCREMENT 346 ptc_d ... block
4.] if IFX license code have separate INCREMENT 346 ptc_d ... block then parametric.psf must contain line similar to the following one
ENV=CREOPMA_FEATURE_NAME=YourLicenseName (346)
Mahesh_Sharma
22-Sapphire I
Hi @ptc-187857 ,
I hope, information shared by Martin help you. It would be great if you can add further information regarding the same. Also listed articles may help:
https://www.ptc.com/en/support/article/CS180439
https://www.ptc.com/en/support/article/CS184483
https://www.ptc.com/en/support/article/CS171139
Mahesh
