intent edge chain selection
- 8 replies
- 6462 views
- Translate All
Hi all,
I saw a tip on selecting intent chains in WF5. :
Select the feature (extrude)
Prehighlight the edge (say the four corners of a rectangular cut for
rounding)
RMB for query select
Supposedly this will select all of the edges associated by that feature (all
of the edges made by the face of the extrude - or all of the edges made by
the extrude that are parallel to the extrude)
This is not working for me. Anyone use this successfully? Am I missing a
config setting? Are there limitations on the type of geometry that it works
on?
Looks like a great tip to use. Any thoughts?
Thanks!
-Nate
rounding)
on?
Thanks!
-Nate
