Mar 5, 2013 10:26 PM UTC
Intersect curves issue
body{font-family: Geneva,Arial,Helvetica,sans-serif;font-size:9pt;background-color: #ffffff;color: black;}Okay Guru's. I'm doing something in WF4 that I haven't done in a while, and am getting results different than I remember. Can anyone tell me what I'm doing wrong here?
I've made 2 sketches, then use INTERSECT to create a 3D curve out of the two. This puts them in a group under the intersect automatically. I don't like that, but understand. The problem is they are now locked and I can't do anything with them. I wanted to copy the curve as a new one, so I could create a similar intersect with different dimensions: NO DICE. The new intersect refers to the same 2 sketches no matter if I check Dependent or Independent.I cannot copy either of the sketches individually, as once I pick one it automatically picks the intersect and sketches as a group. If I delete the intersect, the 2 sketches are deleted with it. I cannot get my sketches back. I had the same thing with a sketch that I subsequently extruded. I couldn't get the sketch back even when deleting the extrude. What kind of stupid behavior is this?
I thought I recall a check box that allows "keep internal features" when deleting a feature, but I don't see that here. Any feedback? any config settings that I have wrong?
TIA,
Jeff
Mar 6, 2013 6:55 PM UTC
Yes, the only difference between the two screen shots is the unchecking of the 'Used Sketches' pick in the model tree display settings.
In fact, you'll notice that 'intersect1' is feature #7 in both images.
I'm on M190.
Jeff - Did you check that model tree display setting?
Mar 7, 2013 10:05 PM UTC
Hi Nate,
Sorry but nothing to add really. Your comment about how we learn the nitty
gritty is good though. Still waiting for the big bucks.
*Brent Drysdale*
*Senior Design Engineer*
Tait Communications
