Invalid left side of assignment message in Line 5 Feature NAME id 6 of Model ASSY
Hi, all,
I have this weird message when I open an assy:
Line 5 Feature GROOVE id 67 of Model 120330:Invalid left side of assignment
Does anyone knows what that means? Beside that I get another one:
Could not read from Model Tree config file $GRI_ENG_CFG/tree.cfg.
which also I don't know what it means.
Thank you,
Nic.
HamsterNL
18-Opal
May 5, 2017
Can you post some more of the PRO/PROGRAM around that feature?
And the relevant RELATIONS also?
Feature in Pro/Program:
IF BN1 != "No"
     IF BN2 == "180 Groove"
         ADD FEATURE (initial number 10)
         INTERNAL FEATURE ID  67
GROUP HEAD
  NO.   ELEMENT NAME  INFO
   1    Name          Defined
   2    Features      Defined
   3    Construction  Defined
         NAME = GROOVE
         MEMBER OF A GROUP, NAME = GROOVE
          LEADING FEATURE OF THE GROUP: ID = 67
          LAST FEATURE OF THE GROUP: ID = 34
         END ADD
         ADD FEATURE (initial number 11)
         INTERNAL FEATURE ID  34
         FEATURE WAS CREATED IN ASSEMBLY 120330_TEMPLATE_ASM
         PARENTS = 1(#1) 3(#2) 32(#9) 33(#8) 5(#3)
CUT: Revolve
   1       Feature Name         Defined
   2       Extrude Feat type    Solid
   3       Material             Remove
   4       Section              Defined
   4.1     Setup Plane          Defined
   4.1.1   Sketching Plane      PL_AXY:F3(DATUM PLANE) ID=6
   4.1.2   View Direction       Side 1
   4.1.3   Orientation          Top
   4.1.4   Reference            PL_AYZ:F1(DATUM PLANE) ID=2
   4.2     Sketch               Defined
   5       Feature Form         Solid
   6       Material Side        Side Two
   7       Revolve Axis         Defined
   8       Revolve Axis Option  Internal Centerline
   9       Direction            Side 2
   10      Angle                Defined
   10.1    Side One             Defined
   10.1.1  Side One Angle       None
   10.2    Side Two             Defined
   10.2.1  Side Two Angle       To Reference
   10.2.2  Reference            PL_XY:F3(DATUM PLANE):120330_TEMPLATE_LINING ID=
   10.2.3  Rev Limit            Side Two
   11      Intersect Parts      Defined
         FEATURE BELONGS TO LOCAL GROUP GROOVE
         SECTION NAME = S2D0004
         FEATURE'S DIMENSIONS:
         OIL_GROOVE_HEIGHT = (Displayed:) 1.99 General_Dims (2.09 1.89)
                             (   Stored:) 1.9945 ( 0.1, -0.1 )
         HP_AUX = (Displayed:) 53.24 General_Dims (53.54 52.94)()
                  (   Stored:) 53.24 ( 0.3, -0.3 )
         d248 = (Displayed:) 33 +/-1 X 45 Deg
                (   Stored:) 32.8 ( 0.01, -0.01 )
         BACK_OF_GROOVE = (Displayed:) 0.9
                          (   Stored:) 0.9 ( 0.25, -0.25 )
         d257 = (Displayed:) 0.90 (1.0 0.8)
                (   Stored:) 0.9 ( 0.1, -0.1 )
         d259 = (Displayed:) 2.79 General_Dims (2.89 2.69)
                (   Stored:) 2.79 ( 0.1, -0.1 )
         GROOVE_RADIUS = (Displayed:) 1.00 General_Dims (1.1 0.9)R
                         (   Stored:) 1.0 ( 0.1, -0.1 )
         GROOVE_ANGLE = (Displayed:) 32.80 (33.3 32.3)
                        (   Stored:) 32.8 ( 0.5, -0.5 )
         GROOVE_WIDTH_BOTTOM = (Displayed:) 2.79 General_Dims (2.89 2.69)
         END ADD
     END IF
END IF
Relations in pro/Program:
/*GROOVE>>>START
GROOVE_RADIUS=BP:1
GROOVE_ANGLE=BR1:1
BACK_OF_GROOVE=CU1
GROOVE_WIDTH_BOTTOM=CV1
CU3 = CU1-CU2
CU4 = CU1+CU2
CV3 = CV1-CV2
CV4 = CV1+CV2
/*GROOVE>>>FINISH
/*PARTIAL GROOVE AT JOINTS>>>START
D515 = 90 - BS1
JOINT_PARTIALGROOVE_RADIUS = BP
JOINT_PARTIALGROOVE_BOTTOMWIDTH = CV1
JOINT_PARTIALGROOVE_OPENANGLE = BR1
JOINT_PARTIALGROOVE_BACK = CU1
JOINT_PARTIALGROOVE_LENGTH = BS1
/*PARTIAL GROOVE AT JOINTS>>>FINISH
/*PARTIAL GROOVE>>>START
D517 = 180 - CW1
IF CW1 > 0
D639 = CW1
ENDIF
IF CW1 < 0
D641 = -CW1
ENDIF
D630 = BS1/2
D634 = BS1/2
BACK_OF_PARTIAL_GROOVE = CU1
PARTIAL_GROOVE_LENGTH = BS1
PARTIAL_GROOVE_RADIUS = BP
PARTIAL_GROOVE_OPENING_ANGLE = BR1
PARTIAL_GROOVE_WIDTH_BOTTOM = CV1
/*PARTIAL GROOVE>>>FINISH
(probably the first block of relations has something to do with the error)
Thank you,
Nic.
2-Explorer
May 8, 2017
Look for the relations for the feature - these are not the part relations.
  • probably relation problem, I can't give you more precise information without having the model
  • $GRI_ENG_CFG is call out of environment variable named GRI_ENG_CFG, which does not exist
MH
I guess there was a feature name called GROOVE that is now deleted or suppressed.
and "Line 5" is referred to what list?
2-Explorer
May 9, 2017
Did you look for the feature relation?
Yes. Here there are the one in the Relations block:
/*GROOVE>>>START
GROOVE_RADIUS=BP:3
GROOVE_ANGLE=BR1:3
BACK_OF_GROOVE=CU1
CU3 = CU1-CU2
CU4 = CU1+CU2
CV3 = CV1-CV2
CV4 = CV1+CV2
/*GROOVE>>>FINISH
And what "Line 5" refers to? Should be a list of relations where the 5th line doesn't work right
