Apr 27, 2015 5:45 PM UTC
Is there a config setting to make Placement constraint Coincident the default as Normal or distance seems to be the current defaults?
Is there a config setting to make Placement constraint Coincident the default as Normal or distance seems to be the current defaults? Taking time to drag a part and orient it prior to placement in a large assembly is not efficient. Most of my assembly constraints tend to be Coincident and rarely (never) Normal.
Dale_Rosema
Apr 27, 2015 8:46 PM UTC
This discussion should help, especially the .pdf presentation,
Re: Assembly constraint default settings......
Thanks, Dale
Dale_Rosema
Thanks, Dale
