Sep 10, 2014 7:20 PM UTC
Is there a way to automatically start up connected to the Windchill91?
Currently I have to login and activate the server and select the workspace. I know you can modify your config.fld to default to a workspace as shown below. Is there a method that once I have login to Windchill it'll activate my primary server (I only have one server).
Example:
C:\Users\Calvin.Ying\AppData\Roaming\PTC\ProENGINEER\Wildfire\.wf\.Settings\config.fld
<xml_document xmlns:soap-enc="&lt;a" style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="http://schemas.xmlsoap.org/soap/encoding/">">http://schemas.xmlsoap.org/soap/encoding/">
<ptc_header>
<vendor>Parametric Technology Corporation</vendor>
<product>Creo Elements/Pro 3102010480</product>
<xml_version>1.0</xml_version>
<host_name>AM00010628L</host_name>
<user>JWAL</user>
<machine_type> Intel64 Family 6 Model 23 Stepping 6 GenuineIntel 2527 MHz</machine_type>
</ptc_header>
<servers_info pointer="TRUE" selected_server="-1">
<servers_nodes_info soap-enc:array="[1]">
<servers_nodes_info_entry type="Windchill" label="Windchill91" online="1" context="Ins" pointer="TRUE" version="4" location="&lt;a" style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="http://plm.inst.strykercorp.com/Windchill"">http://plm.inst.strykercorp.com/Windchill" workspace="Surgicount" ws_locked="0" context_type="4" ws_aval_offline="0"/>
</servers_nodes_info>
</servers_info>
</xml_document>
Jan 28, 2015 10:12 PM UTC
Calvin,
There is a config.pro setting to remember your last workspace. I believe it is dm-remember_server. set it to yes.
Everytime you open Creo, select workspace from the Common Folders tab over in the Model Tree area. It will innitiate a Windchill log-in pop up widow. Once you log-in, Windchill is automatically active and opens to your workspace.
