Feb 6, 2012 11:30 AM UTC
Issue in Ordinate dimensioning
- 2 replies
- 3227 views
- Translate All
Hi All,
I'm facing a issue in Ordinate dimensioning. I'm working in Pro-e (Wild fire 4). I'm facing difficulty in adding ordinate dimensions to drawings which were created by some other users. I could not pick the baseline when i want to add dimensions.
When i pick the base it is showing up a error message "When creating drawing dims only, model baselines may not be used. Select again."
My friends suggested to change config.pro options "create_drawing_dims_only" and "draw_models_read_only" both should to be set as NO.
I have changed the above mentioned options and still i'm facing the same issue.
Did someone here faced same issue.. Please help how to get out of it..
Please see the attached ppt for understanding
Ponraj
