Dec 18, 2012 2:23 PM UTC
Issue with long saving time.
Hi all,
I am having a problem with long save time when I create a part for the first time all other save after I have created the part are fine with no delays . I don’t believe this issue as anything to do with my computer as I don’t have problems with any other CAD program on my computer.
I feel this is a problem with ProE.
Thanks in advance for your help.
Nov 7, 2014 9:15 AM UTC
UPDATE
The issues was solved pro/e was searching locations on our US server I copied over files to UK server and edit the config.pro to reference the UK files only.
Dec 18, 2012 4:13 PM UTC
Hi Mark,
It's the same way for me. When I create a new part it can take up to 2 minutes before I can start working with it. It's not always this way though. I'd say it happens about 75% of the time. While I'm waiting my computer is hitting the hard drive really hard. I don't think it's my system, which implies it's the software. I'm using Wildfire 5.0, M060. It is possible that the start files we are using have some bug stuck in them that causes this to happen. My start files are based on start models from Wildfire 3.0 I think.
Tim
P.S. I know this isn't advice or anything that will help. I just wanted to let you know that you're not alone out there.
Dec 18, 2012 4:43 PM UTC
Do you have a long search.pro? I suspect that the long first save time may be because Pro/E is checking that no other file exists with the same name (although I believe it also checks that when you first start the new part).
Dec 18, 2012 5:49 PM UTC
Please post your version and if you are using Windchill. In Creo 2.0 M030, saving a new part is very fast.
Dec 19, 2012 8:07 AM UTC
Hi all,
My Version is Pro Engineer Wildfire 5.0 M010, I don't think I have Windchill.
"Do you have a long search.pro?" Can you please tell me more about this, where can I find it or turn it off.
Dec 19, 2012 8:38 AM UTC
search.pro is a list of directories that Pro/E will look in to find a part or drawing.
It's typically called up by a line in config.pro such as:
search_path_file z:\defaults\search.pro
and then search.pro itself is simply a list of directories:
z:\project1
z:\project1\clientdata
z:\project2
z:\project3
z:\standard-parts
etc.
If search.pro gets particularly long, it can slow Pro/E down on certain operations (such as rename) because it has to look through every single directory listed before it's sure that the name doesn't already exist somewhere else.
It's extremely useful if you're working without Windchill, but needs keeping tidy.
Dec 19, 2012 7:02 PM UTC
I don't think it's the search path. My search path only has two directories in it.
ptc-46444611-VisitorAuthorAnswer
UPDATE
