Nov 5, 2015 6:55 PM UTC
k factor sheetmetal config fille
hello
i want set k factor as 0.5 by default in config fille
somebody help me with sin
Nov 5, 2015 7:31 PM UTC
PTC uses a Y-factor, not a K-factor that the rest of the world uses.
See my posting from earlier this week for a link to an explanation of the two.
The config.pro setting is: initial_bend_y_factor and the default is .5.
Once you are in Creo and a sheetmetal part, you can change the part parameters to use the K-factor.
This will set the factor type: SMD_PART_BEND_ALLOW_FACTOR_TYPE
This will set the allowance you want:SMD_PART_BEND_ALLOWANCE_FACTOR
Nov 5, 2015 7:40 PM UTC
Link to the other K factor discussion.
k factor
