Jun 15, 2015 1:51 PM UTC
keep creo 2 and 3
I have customer still using  creo 2.0 M120 and me I want use 3.0.
Can we keep both version???
Bests Regards.
Francois
Jun 26, 2015 2:32 PM UTC
Hi I install last week both version of creo and they run well.  thanks all for answer
Jun 15, 2015 1:57 PM UTC
Yes, just install into a different root folder.
Jun 15, 2015 2:18 PM UTC
thanks you
Jun 15, 2015 2:19 PM UTC
thanks you
Jun 15, 2015 2:02 PM UTC
yes bro,.........
but u instel in different os. if u do not then it will hang ?
Chris3
Jun 15, 2015 2:35 PM UTC
You can have both versions installed and they will both work (I have both installed right now).
Keep in mind though that they are not backwards compatible like most Microsoft Office products are. As soon as you save something in the newer version you will not be able to open it in an older version. The caveat to this statement is that there is a complicated plugin that does allow you to open newer files with the older versions but it does not restore full functionality. It only allows you to add features in the older version which you can then use in the newer version. It also doesn't always work correctly.
PTC Creo GRANITE Interoperability Kernel
Jun 15, 2015 2:47 PM UTC
Yes I saw this I open with my M060 drawing M120 and had some red things and my went I resend the drawing the red things disapear.
Nice answers thanks you.
thanks all
Jun 15, 2015 2:43 PM UTC
you can installed both version  in one system, like w-7,8.1,8 , XP etc like ,then u can easilly work
Jun 15, 2015 2:48 PM UTC
yes ok thanks
Jun 15, 2015 2:49 PM UTC
most wellcom
Otherwise u uninstalled creo 2, then after installed creo 3, this is the batter way bro............
Jun 15, 2015 2:53 PM UTC
I want keep 2.0 only for this customer. Now I had install M120 and try install 3.0 M040. But I'm affread to erase the possibility to work with this customer who keep 2.0.
Now with all your answer I known is it possible.
thanks all
Jun 15, 2015 2:59 PM UTC
no  no don't worry  .......... nothing  deleted ............carry on........................
Jun 16, 2015 4:12 PM UTC
As others have said, there's no issue with installing multiple versions.  I have WF4, WF5 and Creo 2 on my machine right now.  All my work is in Creo 2 at the moment, but like you, I need to be able to use what my customer uses.
Some things to keep in mind, however.
  1. Don't use the "double click to open" function to open Creo / Proe files.  The last version installed will be the one associated with Creo files and that one will launch, regardless of which version the file was saved in.
  2. Starting with Creo, windows customization (tab layout, quick launch buttons, etc) are stored deep in the user's profile in the "cache".  Creo makes no distinction there between versions, so Creo 3 and Creo 2 will try to use the same windows customization file.  I'm not sure if this will cause issues or not, we set the cache folder for each version to avoid this.
  3. Be aware of where your config files are stored.  If you are just storing them in the <load point>/text folder, then each will have its own files.  If you are using another folder, I'd give each version it's own config folder.  That's what we do.
fbrouillard1-VisitorAuthorAnswer
Mahesh_Sharma
22-Sapphire I
Jun 26, 2015 3:44 PM UTC
Francois,
You may mark appropriate replay to post as correct answer or add more information to post to mark that as correct answer.
Jul 24, 2015 3:25 PM UTC
yes
