Lattice full geometry error
Hi everyone, I'm working in some lattices, normally I work with simplified geometry, for testing and visualization, and when everything is okey, I go back to lattice command, and turn from simplified to FULL GEOMETRY, I perform the lattice, but then the error occurs, any idea of what's happening?? why in simplified works and in full not.
Sergi
any screen capture and file attached to the case may help others help you.
23-Emerald V
January 15, 2020
Which computer/software application is this about?
Mathcad or Prime? Then a worksheet detailing/illustrating your question is needed.
Any other application? Move this question to an/the appropriate forum.
I think this question erroneously  ended up here in the Mathcad forum and should be moved to the Creo forum (?) by a helpful mod.
