Jan 11, 2010 1:50 PM UTC
Layer Strategy, Legacy part clean up
Hello, Although I am sure this subject may be covered elsewhere, it is challenging to search through all of the topics and threads, so I thought I would start a new one. I have just started as a ProE admin. and one of our first tasks is to clean up how users are using layers. The following are what I want to do: 1. include a robust yet minimal layer config file and matching start part 2. Determine and implement a policy, process and compliance to make this work 3. develop a batch script that will go back into older parts and move features onto the appropriate layers (as defined in the new schema) I do have ModelCHECK and ProBATCH if either or both of these can be leveraged? Thanks so much for any and all lfeedback, David
Jan 14, 2010 2:57 PM UTC
Hi David, Our group does this with model check. As an end user it is a few clicks for me to clean up most models. Standard layers and parameters are added/renamed to the model, non standard layers are deleted, features are moved to appropriate layers, layers are set to hide or unhide. Model check does a nice job on most models. I was not involved in the setup so I can not help much with that. I suggest getting the end users involved if you can, maybe set up a simple routine to show what can be accomplished and get their input. There is a lot of information in the help topic collection for model check. Best regards-
Jan 14, 2010 5:29 PM UTC
Hello David, you could use extend layers - create a dummy asm with a set of rule based layers. - delete all layers from your out of standard asm and prts - assemble them in your dummy asm - mark all layers in your dummy.asm - extend layers - Your rule based layers are applied to all components greets Reinhard
