Apr 7, 2015 7:13 AM UTC
license error
hi,
i am working on a system which is a server for creo 3.0. we total of 3 licenses. My colleagues who are working on creo 3.0 on other system are frequently facing license lost error.
Each time they loose their license i have to manually restart Lm admin utility in my system. I have to do it in every 2 hours approx. Is there remedy for this error.
Thanks in advance
Regards
Apr 7, 2015 7:25 AM UTC
You need to file a support case. This is often a time-out issue on the server. This should be easy for PTC customer support.
Apr 7, 2015 7:29 AM UTC
Samuel,
your problem is site specific. Probably your network does not enable Creo workstations to communicate properly.
Martin Hanak
Apr 7, 2015 9:42 AM UTC
PTC's "Case Logger" is here: https://support.ptc.com/appserver/cs/case/case_logger.jsp
