License Failure - Bad message command
I am getting this message when I try to launch Creo 4 M050.
7788@<server>: (-140) Bad message command
The FlexLM admin guide just has the text: Bad message command.
I am running on a server (Windows 2008) and the software is loaded locally.
The license file is valid because I have a shortcut to a network install of Creo 4 F000 on my server desktop pointing to the same license file and it launches fine.
Only the new install of Creo4 M050 fails.
I have never met such error message. Can you upload psf file ?
BenLoosli23-Emerald IIIAuthor
Martin,
That pointed me in the right direction and I checked the parametric.psf and found some extra characters on the feature line. Removed them and it now starts.
