Jul 29, 2020 4:27 AM UTC
License found during installation, but when starting CREO 7.0.1.0. cannot connect to server
We have run into a problem setting up our floating licenses. The server is up and running and the licenses are found with no problems during the installation. However, when starting CREO Parametric, the program is unable to connect to the license server... Initially, the port was blocked, but before that issue was lifted, the server wasn't even found during the installation.
How should we go about fixing this?
Jul 29, 2020 7:09 AM UTC
Have you unblocked BOTH ports? Creo needs two ports to be open to succesfully connect to license server: 7788, which is default port for flexnet license manager and random port for ptc_d.exe, which is actual license daemon, serving Creo license.
You can also configure license server to run ptc_d.exe on specific port, so you can unblock it on your firewall.
TSiik1-VisitorAuthor
Jul 29, 2020 7:15 AM UTC
As suspected only the port 7788 has been unblocked.
How can we configure the ptc_d to run on a certain port? Didn't find anything on the topic on the run.
Jul 29, 2020 7:43 AM UTC
You can do that in two ways:
1. Log in to license server web interface, go to Administration (upper right corner) and then go to Vendor Daemon Configuration, select ptc_d and then configure vendor port.
2. Go to installation location of the license server (C:\Program Files\PTC\FLEXnet Admin License Server), go into Licensing directory, edit license.dat (even with Notepad, it's a simple text file) and find
DAEMON ptc_d
line. At the end of the line add port number you want to use (similar to 7788 in the SERVER line above) and save the file.
Restart license server service and ptc_d should be using only specified port.
Jul 30, 2020 6:06 AM UTC
to verify that the problem is related to firewall (incoming rules), you can turn it off temporarily.
Mahesh_Sharma
22-Sapphire I
Aug 3, 2020 12:41 PM UTC
@TSiik
IN addition to all inputs from community members, try adding server details (IP and name) in client host file available under C:\Windows\System32\drivers\etc
