Mar 17, 2015 10:40 AM UTC
License request failed for feature
hello.
my support has expired and I can not use.
now I have a problem when I should start my Creo 2 with this error Notice:
would you please explain how I should do?
Mar 17, 2015 2:21 PM UTC
Reza,
locate std.out file in your working directory, open it and copy its contents into your next Reply.
Martin Hanak
rtaleb1-VisitorAuthor
Mar 17, 2015 8:32 PM UTC
Requesting PROE_FoundationAdv ...
7788@reza-w8: (-97) The desired vendor daemon is down.
Mar 18, 2015 5:28 AM UTC
Reza,
is reza-w8 the only one computer ? This means ... is reza-w8 used as license server and also as Creo workstation ?
Or is reza-w8 used as license server and second computer as Creo workstation ?
In this second variant, license server can be blocked by Windows Firewall. You can turn it off and try starting Creo.
Martin Hanak
Mahesh_Sharma
22-Sapphire I
Mar 17, 2015 5:41 PM UTC
Reza,
Please provide complete error message information, better a snapshot.
Mar 17, 2015 8:35 PM UTC
Mahesh_Sharma
22-Sapphire I
Mar 17, 2015 10:26 PM UTC
Browse to system services (Start > Type Services) and look for lmadmin_ptc or flexlm server for PTC. You may have one out of those, select that Right Click and Start or Restart.
> Start Creo.
If this fails:
Open PTC License Server Tools > Config services > View log > and check for any error in last few lines. If any please add to reply in the post.
