Mar 21, 2013 3:38 PM UTC
License Server Setup
Alright I have what is possibly a stupid question but... How do you update/install a license server with Creo installer now?
With Wildfire5 there was a "Install License Server" option to click. With Creo I can't figure it out.
I had to get an updated license file, but now I can't figure out how to update it on the server.
Any help is appreicated.
Mar 22, 2013 7:54 AM UTC
Erik,
PTC supports following combination (I use it for a long time):
1.] FLEXnet installed from Wildfire 5.0 installation DVD (version 10.8.*)
2.] Creo Parametric 2.0 (any maintenance release)
This means ... you are not forced to use FLEXnet 11.* present on Creo 2.0 installation DVD
Martin Hanak
Erik,
Martin Hanak
Apr 22, 2015 9:21 PM UTC
Hello Martin,
do you know how I can update my license for Creo3? I have relocated my computer from one room to another and the physical addresse changed a little bit so that Creo3 is not working anymore.
Best regards
Georg
Mahesh_Sharma
22-Sapphire I
Apr 22, 2015 9:27 PM UTC
Georg,
If you have commercial license, contact PTC license management and ask for license transfer from old physical address to new one. However as you mentioned you relocated your computer, relocation will not change the physical address. Were there any changes in computer hardware? If no, possibly network card priority might have changed. Check all physical addresses on computer and see if you have one which was available earlier. What error message you are getting in Creo 3.0?
