Licensing
The computer at my office is down. I am trying to work from home using a floating license for Creo Parametric. I am unable to get Creo Design advanced to operate correctly. I believe the license is locked to the computer at work as I can only access the floating Design Essentials license. Is there a way to transfer the locked license? My replacement  computer won't be ready until next week and I'll need to set that up as well.
2 options
1) take your laptop from home to the office, connect to the network and borrow a license
2) transfer the license from your work computer to your laptop and then transfer back when the system is restored
The video card in the computer at work is fries, I'm unable to access it. Is there a way to transfer the license without having access to the hard drive on the computer at work?
You said floating license, so I assumed the licenses are on a server, not your workstation. If the license server is down, then the temp license transfer is the only method. But you said you can get 1 license, so are the licenses floating or node locked?
