Licensing error launching student ed. of Creo 3.0 for the first time
  • May 19, 2015
  • 4 replies
  • 1434 views
No problems with the download. When I initialized Creo I received this error:
After that the program closes. I have others in my class that have the same problem. Any help would be appreciated.
When you scroll down underneath that error what does it say?
sgrassi-21-VisitorAuthor
Nothing.
Scott,
complete text of the warning is saved in std.out file located in Creo startup directory.
The name of the license must be properly set in parametric.psf file in Creo installation bin subdirectory.
Martin Hanak
2-Explorer
June 3, 2015
Hello Scott,
Did the hint from Martin help you detecting the cause?
If yes, please take the time to mark his answer as correct (or as helpful, if it has inspired a solution that was different).
But I believe that is exactly what he suggested: Creo Parametric 3.0 has not been configured - see CS198207
Gunter
